Results 1 to 3 of 3
Thread: question / help
    TV Addicted gotcha772's Avatar
    Oct 2017
    YES I DO
    question / help
    ok I have a mag254 that just started saying resolution mismatch change device settings so ok , I check my res its 1080p 1280x720 so at first I made sure all res was set to same , then powered down used the menu key to open device settings now everything is reading same res save and reboot comes back on says same thing so I read where res was changing to 1080h/264 went back into the device no such setting n the 254 so just for trouble shooting purposes I changed the setting to auto , saved changes reboot , comes back on happened to b on a fox channel I engaged the channel it says same thing so I change channels a cpl times it no longer says anything so I reboot again and it says it again same message ; any idea's on this ; I have to be missing something simple some where ....
    Super Moderator at Work catz's Avatar
    Use your rca cables and set the res to 720.
    Oct 2017
    YES I DO
    I think , I got it that time thanks ..
  1. P3 question
    By Tvhound in forum IPTV Private Server (NFPS)
    Last Post: 05-17-2017, 03:34 PM
  2. got one more question
    By Marley in forum Computer Discussion
    Last Post: 04-02-2016, 03:54 PM
  3. question
    By motley22 in forum IPTV Private Server (IPTV66)
    Last Post: 01-27-2016, 03:05 AM
  4. VPN Question
    By imp02ala in forum Chit Chat Lounge
    Last Post: 01-24-2016, 08:00 AM
