Results 1 to 10 of 10
    Nov 2015
    Help me choose a new box for iptv
    I currently have avov onlinetv+ (red box)
    Its time for a new one
    I only use it for IPTV
    I used to use it for Kodi.
    not anymore, dont work with this box.
    (is kodi working?)
    Those of you that have tried different boxes please tell me which work best.
    Thanks,
    Cheers!!!!!!!!!!!!
    Mercenary floder2's Avatar
    yea
    Quite a few work well .............Try looking in the forum under each Box listed and you can read all the posts about those boxes ............quite informative ....I'm sure you will be able to make a decision by then...
    YES, Kodi IS Working and doing just Fine with a few Tips, Tricks and Tweaks...!
    Mar 2016
    yes I do
    Bought this one on amazon.ca a few weeks ago. Very fast, no problems so far. Use with ProgTV and Kodi
    Best of the 3 boxes I have...also the newest, of course.
    www.amazon.ca/gp/product/B07GJN3FG5/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    Would suggest you stay away from the 8GB ROM, 1GB RAM models. One of mine is 8/1 and the other 2 are 16/2
    The 8/1 model is very much slower than the other 2.
    @ hadcroft :
    • Outside links must always be coded.
    - Put [/code] at the end of the live link and [code] at the beginning of the live link... or
    - Choose "Go Advanced," highlight the link, click the # symbol on the right-hand side of the editor's tool bar.
    Very Important Rule You Missed...!
    Mar 2016
    yes I do
    4me2c
    Thanks for the education. Have to confess, I didn't read any rules after joining this forum and now that I look for them,
    dammed if I can find them. Could you please point them out.
    Appreciate the work such as yourself do to make this site possible.
    You are Welcome, Enjoy the Site :
    http://iptvtalk.net/showthread.php?37579-Forum-Rules
    Formuler, Dreamlink, Buzz, and Xtreams are the current front runners. Read up on them in the forums and you'll find one that will work for you.
    A good rule of thumb is to buy from a registered dealer, if you don't most likely you will have no warranty
    In the forms stickies the the box you are there will be a where to buy
    Nov 2015
    Thanks Folks,
    I bought 2gb/8gb BuzzTV XPL 3000m
    nice speedy little unit.
    Cheers.
  1. Help me to choose an Android box
    By Vuvuzela in forum Android TV Boxes
    Last Post: 03-13-2016, 03:00 PM
  2. Renew Order , did not choose IPTV
    By lr00tz0 in forum IPTV Private Server (IPTV66)
    Last Post: 01-20-2016, 03:06 PM
  3. Best iptv app to choose
    By Ian Hunt in forum IPTV Private Server (Rocket)
    Last Post: 01-03-2016, 07:13 PM
  4. Which box to choose
    By Mib150 in forum G-Box Midnight MX2 Android TV Box
    Last Post: 11-27-2015, 05:44 AM
  5. Why choose a MAG 254?
    By guest in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 04-11-2015, 12:22 AM
