Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: terrarium
  1. #21
    Oct 2015
    hmm seems its down again with patch
  2. #22
    Quote Originally Posted by curgs View Post
    yes, I heard the patched version went down yesterday morning sometime.
    May be time to look for another source
    - Frank Zappa
  3. #23
    Oct 2015
    thanks for the update
  4. #24
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Worked 1 day, ...Typical!
  5. #25
    Mercenary floder2's Avatar
    yea
    I heard an adblocker can make it work again........reason it crashes is because it's being diverted to a NitroXenon site....that makes the app crash...adblocker will block the site and then the app works...
    I suggest using............TeaTV ... Movie-HD-Lite ....or FreeFlix HQ ......instead
  6. #26
    yes I do
    terrarium is back up and running fine with no blocker mods needed. Checkout Husham site to download the updated version. I have been using it for a day now and it works great
  7. #27
    Oct 2018
    Yes I do
    There is a new fix for TTV going down again........get AdGuard or Blokada and enter "blog.nitroxenon.com" into it......there are a lot of youtube videoes telling you how....It works fine again......I had just paid for 3 months of Real Debrid.....I'm so glad it's back up...
  8. #28
    Oct 2015
    Husham only works for tv shows ,, still no data in movies
    also added blog.nitroxenon.com in blokada,,,, but movies do not work , no data
  9. #29
    Warrior
    patch 2 version from newtechonline has movies
  10. #30
    Banned
    It is time to move on from terrarium guys, lots of other similar program around to be wasting time on this.
