Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: terrarium
    Quote Originally Posted by floder2 View Post
    Yes it's developer has announced he is shutting it down .................. try...... FreeFlix HQ .....similar
    Are you able to get FreeFlix HQ to work on the BuzzTV? I loaded it and it simply will not work for me. It says something about my device is not compatible. My BuzzTV is an older one that is still running Android 6.something. I load an older version of FreeFlix HQ on the BuzzTV and it tries to work but then FreeFlix HQ pops up with an "upgrade" window and you have to upgrade or the app closes. When I upgrade I'm back to my device not being compatible. I tried loading FreeFlix HQ on my LG phone which is running Android 7.0 and I still get the message my device is not compatible so I don't think the Andriod version is the issue. I loaded FreeFlix HQ on my W95 box running Android 7.2 and FreeFlix HQ runs flawlessly.
    Oct 2015
    terrarium patch does not work,,, downloaded it right from koditips, but it will not install on my buzz
    Mercenary floder2's Avatar
    yea
    Quote Originally Posted by curgs View Post
    What are you using to install that file.............. I have had trouble with the App Installer provided in the Buzztv box.....Try downloading a different App Installer from Apptoid or Google play store
    Banned
    Nov 2017
    in front of pc
    you also can use file manager
    Oct 2015
    none work... tried es, file manager and file browser,,,, downloaded it twice , once to usb stick and once right from buzz browser from kodi tips, keep getting apk not istalled
    yea
    Never had problems with those apk's with the Buzztv Basic or regular Buzztv 2000 and 3000 models
    Oct 2015
    rookie move on my part,,, thought this was just a patch to existing and latest version of terrarium 1.9.10,,,, had to uninstall that version, now all is good
    yea
    Glad to hear that.....remember not to choose Yes player as you default .............try MX player instead
    Oct 2015
    thanks for the heads up
    Just Checked to see what all the hubbub is about and have to say... WTG ...!
  1. terrarium TV
    By gotcha772 in forum Formuler Z7 & Z7+
    Last Post: 09-21-2018, 07:31 PM
  2. Terrarium Update
    By GaryF in forum BuzzTV 3000 series models
    Last Post: 06-13-2018, 04:38 AM
  3. terrarium?
    By shmed in forum BuzzTV 3000 series models
    Last Post: 03-28-2018, 09:42 PM
  4. Terrarium tv
    By Jimc197 in forum Dreamlink T1 Plus
    Last Post: 11-11-2017, 02:13 AM
