Results 1 to 10 of 13
Thread: Firmware Update
    Copernicus Crater
    Firmware Update
    WARNINGS:
    FIRMWARE CANNOT BE ROLLED BACK ONCE INSTALLED.
    DO NOT USE THIS BETA SOFTWARE IN PRODUCTION ENVIRONMENTS.
    Please test and report your findings through the established channels.
    Firmware Version: 1.2.34
    Release Notes:
    FIX: Stuck in standby mode
    FIX: Market > Certain apps not showing in custom markets
    FIX: Launcher icons not appearing after reboot
    Added discrete Power ON & Power OFF keycodes
    Custom Android hostname/device name supported. Change from the system menu
    Market shortcut can be deleted from the homescreen
    FIX: Installer Mode > SYSPIN issue
    FIX: Installer Mode > Langauge preset not working
    FIX: Installer Mode > Power mode preference issue
    DRIVER: Add Tenda U12 USB WiFi adapter support
    Android Security Patch Level : April 2018
    General performance enhancements, UI improvements, and bug fixes
    Improved Lithuanian language translation
    DOL2 / MYTVONLINE Version: 1.9.48
    Teletext Subtitles supported
    Manual EPG time offset. Access from the Settings menu
    Xtream-Codes API portals > TV Series section supported
    VOD > Continuous play option added. Press the Green hotkey to toggle
    M3U > All tracks from VOD-only m3u list are parsed and used - regardless of stream file extension
    M3U > Compressed xmltv EPG archives supported (.gz or .zip)
    Automatically hide empty groups/categories
    Added stream codec details. View from the detailed information popup window
    TV Series Shortcut. Press and hold the VOD button on the remote
    Remember last selected subtitle preference per channel
    Improved channel icon caching
    Improved EPG download performance
    FIX: EPG description not displayed when using M3U + XMLTV EPG
    FIX: Black subtitle font when only 1 subtitle track is available
    FIX: RCU VOD hotkey while in Classic Channel list
    Anyone tried it yet?
    Copernicus Crater
    Quote Originally Posted by crazy carl View Post
    I updated my T2 and Formuler last night. Havent been home to really see any improvements yet.
    Will be later tonight for me to check any improvements
    I did see that the EPG Time was correct or so Im thinking it was. lol
    Unable to download update stuck on zero. Re-booted box and same results. has the update been pulled?
    Aug 2018
    Internet
    Quote Originally Posted by Capt.Kangaroo View Post
    What are the established channels to report to?
    I updated to the beta version. Will there be any problems when the official version is released or am I going to be on the beta update channel from now on?
    Quote Originally Posted by starRyder View Post
    I just updated less than 5 minutes ago. It's a beta update. Hit the red button on your remote.
    'established channels' is referring to their online beta testing chat sites. Mostly this refers to the Formuler chat site (Telegram Channel).
    We at iptvtalk are also an established channel for the dreamlinks, so reports can be posted here too.
    'Official releases' should be seen within a couple to a few weeks, which you will be able to update then without any problems. But if this current beta firmware is loaded now, then you will not be able to roll back to the last Official firmware release.
    I have heard so far that the epg may be loading a bit slower with this newest beta DOL/MOL beta release.
    But that is the DOL upgrade and not the actual firmware (refer to release designations in Captain's notes from above). You can reinstall the older DOL (or MOL in Formuler's case), but can not roll back the actual firmware from this beta.
    You would simply delete the present DOL and then re-install the original DOL or MOL from the market to roll back the DOL/MOL versions.
    Aug 2018
    Internet
    Quote Originally Posted by crazed 7.2 View Post
    You would simply re-install the original DOL or MOL from the market to roll back the DOL/MOL versions.
    Cool. Everything seems to be working fine so far.
    Thanks for the info!
    I believe !
    May 2016
    Both of my t2 are working perfect so far
    if you are still stuck at zero and can download software then try this.
    click update in settings first
    then hit red button
    when you see release note then scroll all the way down
    now hit ok button and you will be able to download.
    hope this will help.
    Aug 2018
    Internet
    Beta IPTV v1.9.48 has been giving me some minor issues ever since I upgraded from v1.9.43
    1) There is a 2-5 second delay/lag when you change channels. The information bar at the bottom of the screen will change instantly; however, the picture will still show the previous channel for 2-5 seconds before switching to the new channel.
    I've compared it side-by-side with v1.9.43 which doesn't have this issue. With v1.9.43, the information bar and channel will both change at the same time when you change channels.
    2) When you press the power button to turn off the box, the light on the front will go away and the picture will go away but the audio will still remain for another few seconds until the box completely shuts off and the red light shows up.
    With the previous version 1.9.43 both the audio and video would cut out as soon as you press the power button.
    3) There was a picture frozen on the screen after turning on the box from standby. It was a really strange issue.
    I can open up the guide, use both the classic and normal channel list, and change channels but no matter what I do it will show the same frozen picture. The audio would change but not the picture. I could even open VOD but no matter what I play it will only play the audio but show the same frozen picture.
    I put the box in stand-by again but still the same issue. I also force-closed the app and reconnecting to the portal but still the issue remained.
    The video started coming back only after I rebooted the box. However, the app crashed and rebooted itself as soon as I went into VOD.
  1. Replies: 4
    Last Post: 10-25-2022, 08:06 PM
  2. Firmware Update
    By wee-haggis in forum Dreamlink T2
    Last Post: 01-08-2019, 07:01 PM
  3. New Firmware Update
    By Capt.Kangaroo in forum Dreamlink T2
    Last Post: 04-25-2018, 02:24 AM
  4. Firmware update
    By klama in forum aVOV TvOnline+
    Last Post: 10-22-2015, 02:29 PM
  5. About next firmware update , the coming X8-H Plus firmware
    By theone in forum Minix Android TV Box
    Last Post: 12-16-2014, 08:56 PM
