Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Dec 2017
    My friend had the same problem and found out later that his kid had changed to a higher resolution thinking he would get a better picture but it locked down his mag from loading.If you make changes in BIOS make sure you hit EXIT & SAVE.My bios settings are (720p-60)(1280x720)(nand).
    Quote Originally Posted by tonyd33 View Post
    Thats what mine are set at.
    https://youtu.be/nXuDmmoqtxA
    Are You doing what this shows at 1:02 in...?!?
    Not sure but, I have a MX Box that looks similar to Your STB, in the back there is the AV Port and I can stick a wooden Toothpick inside slowly till it bottoms out and then I can fell a Click which is another way to Re-Boot and Reset the STB...! Again, Not Sure if that will work with Your Stab... Other Boxes have that availability also : http://iptvtalk.net/showthread.php?36759-pin-hole-reset
    Dec 2017
    Try another HDMI cable.
    Did that already
  1. What am I doing wrong??? Mag box 254
    By Tibby2k in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 07-29-2016, 01:55 PM
  2. Something went wrong
    By jenkins76 in forum IPTV Private Server (NFPS)
    Last Post: 05-16-2016, 06:13 PM
  3. Did I get the wrong box?
    By Alex9483 in forum Kodi Discussion
    Last Post: 03-26-2016, 06:58 PM
  4. what wrong
    By javydiamante in forum IPTV Private Server (NFPS)
    Last Post: 02-26-2016, 07:30 PM
  5. Wrong IP
    By smitty1952 in forum aVOV VIXO1
    Last Post: 01-06-2015, 06:34 PM
