Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 69
  1. #51
    Jul 2015
    Mexico
    Quote Originally Posted by tonnynels View Post
    Hi diode, not yet.
    My last attempt would be to test a new account, however I requested a free trial and did not get it.
    I'm almost given up, remains only three days for me.
    ask crazed 2.0 if he will help, give him your code he can check it out and can be trusted.
  2. #52
    There's nothing wrong with account. It has been checked. It works fine at his friends house, in fact. This situation just keeps going around in circles. I've suggested using a free VPN to figure out whether or not the ISP is responsible for the issue, but that avenue hasn't been pursued.
  3. #53
    Ambassador
    Dec 2016
    I thought VPNs were not allowed. No true?
  4. #54
    They're not allowed for continuous use. This is for testing purposes only. In this case, install the VPN, fire up the service. If it starts working, he'd know the ISP is the issue. At that point, he'd need to decide whether or not to choose a new ISP.
    The other option is to find someone else who has the same ISP and test it there. If it doesn't work there either, then all signs point toward the ISP, and issues with his modem or router being the culprit are pretty much ruled out.
  5. #55
    I wanted to let everyone know that indeed your service will be tagged with a warning if they see the VPN in use.It is done thru their datacenter, so it is automated and will see the VPN in use. I recently received a message from a fella that had received a warning thru his email that a VPN was in use thru his code
    Ilan and myself have said that this is risky to do this and at your own risk.
    I have also known about a fella that has used a VPN for quite an extended time period, and he told me that the IP only changed once over that time and he never received a warning.
    so remember guys, do so at own risk
    Again, the VPN in this case is not for streaming; it's for testing. Since he can't use the service at all at this time, testing with a VPN won't pose much of a risk for him. However, I wouldn't use a VPN with a working service. It would definitely put you at risk.
  7. #57
    yup.. i gotcha and agree fully
    I have told this same thing to people in the past
    Jun 2018
    Yes, route 66 works with VPN.
    What can I do now?
    In this configuration I need to change the country to the USA in order to match the one available VPN country.
  9. #59
    I was almost certain this is what would happen. I didn't think it was a congested route or an issue with the modem or router.
    That being said, about the only thing you can do now is to go with a different ISP. If you stream with the VPN, you will almost certainly be detected and get booted. At least now, though, you know what is going on and can make an intelligent decision as to the direction you want to go.
  10. #60
    Jun 2018
    Is there a way to use Opera browser as a player?
    Is there a way to use MAC Address in a Minix Android Box?
  1. EPG is fully populated
    By MrPat in forum Dreamlink T2
    Last Post: 12-28-2017, 04:44 AM
  2. Five arrests in 'fully loaded' Kodi streaming box raids
    Last Post: 02-09-2017, 03:32 PM
  3. guide not fully updating
    By Justme in forum EPG (epg.ninja)
    Last Post: 04-26-2016, 12:16 AM
  4. Replies: 1
    Last Post: 11-09-2015, 02:46 PM
  5. Fully setup PAID NFPS working but few questions please.
    By sig1 in forum IPTV Private Server (NFPS)
    Last Post: 07-28-2015, 08:21 PM
