Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 69
  1. #21
    Jun 2018
    Quote Originally Posted by diode View Post
    I wish I had another suggestion. I think if it were me I'd unplug the modem and leave it off overnight and try it in the morning. You might have to switch ISP to what your neighbour is using.
    Hi, diode !!
    Thank you again for your suggestion.
    I unplug the moden/router every night. I use to do it with all electric equipments at home (except refrigerator and freezer).
    If you knew someone with the same ISP as yours, it would be nice to try it there, to see if you get the same results. If you do, it would rule out variables other than the ISP.
    ilan, it is a good idea, but I don't know how to accomplish it.
  2. #22
    I bet if you do a tracert on that, you will find alot more hops with your's compared to your neighbor's.
    I also bet that if you setup your own server host and direct traffic to there and then from there to iptv server (and vise a versa), then it would work.
    I am pretty sure that this issue is how your traffic is handled by your ISP, the URL is not being resolved correctly and after much ado it finally sees the URL but looses the packets because of the 'much ado' thing
    Just a theory
    Go back to your command prompt and ping the server again. Look at the bottom of the results for packet loose information.
    By the way, tracert is done same way thru that command prompt as is the ping option is performed.
    Just type 'tracert' instead of 'ping'
    Jun 2018
    Quote Originally Posted by crazed 7.2 View Post
    Just a theory
    Thank's crazed 7.2
    I found these results:
    The last one (number 9) takes a long time to appear the address (more than 2 seconds)
    C:\Users\tracert s1.iptv66.tv
    Rastreando a rota para s1.iptv66.tv [104.24.1.119]
    com no máximo 30 saltos:
    1 5 ms 2 ms 2 ms 192.168.1.1 [192.168.1.1]
    2 7 ms 6 ms 8 ms 175.251.40.189.isp.timbrasil.com.br [x]
    3 9 ms 10 ms 10 ms 10.216.250.69 [x]
    4 12 ms 38 ms 13 ms 10.216.250.21 [x]
    5 14 ms 14 ms 13 ms 10.223.238.77 [x]
    6 7 ms 7 ms 7 ms et2-0-0.sanpaolo8.spa.seabone.net [x]
    7 118 ms 118 ms 119 ms et1-1-0.miami19.mia.seabone.net [x]
    8 124 ms 119 ms 119 ms cloudflare.miami19.mia.seabone.net [x]
    9 118 ms 120 ms 118 ms 104.24.1.119
    Rastreamento concluĂ*do.
    Below my neighbor ISP
    C:\Users\milto>tracert s1.iptv66.tv
    Rastreando a rota para s1.iptv66.tv [104.24.2.119]
    1 1 ms 1 ms 1 ms 192.168.0.1
    2 10 ms 10 ms 10 ms 10.28.xxx.x
    3 9 ms 11 ms 9 ms c9062241.virtua.com.br [x]
    4 10 ms 9 ms 11 ms c90628c9.virtua.com.br [x]
    5 9 ms 11 ms 11 ms c90628d1.virtua.com.br [x]
    6 13 ms 12 ms 10 ms c9062a0e.virtua.com.br [x]
    7 12 ms 11 ms 14 ms c9062a0d.virtua.com.br [x]
    8 11 ms 12 ms 10 ms embratel-T0-4-0-1-uacc03.spomb.embratel.net.br [x]
    9 16 ms 14 ms 16 ms ebt-H0-15-0-0-tcore01.spolp.embratel.net.br [x]
    10 17 ms 19 ms 18 ms ebt-B1171-tcore01.spoph.embratel.net.br [x]
    11 12 ms 11 ms 11 ms ebt-H0-5-0-0-puacc03.spo.embratel.net.br [x]
    12 13 ms 15 ms 17 ms peer-B53-1702-puacc03.spo.embratel.net.br [x]
    13 16 ms 12 ms 11 ms 104.24.2.119
  4. #24
    Jun 2018
    How do I do it?
    Something to set up in my modem/router?
  5. #25
    Jul 2015
    Mexico
    maybe you need a new router? you don't have an extra one laying around do you?
    the more i think about it the more i think it's the router hardware.
  6. #26
    Jun 2018
    Quote Originally Posted by Sandiver View Post
    Hi Sandiver, thank's for your suggestion.
    My router is a modem/router that belongs to the ISP provider, however I also use another router connected by cable to a router in the TV room.
    I understand your point, but as I have internet access and other free IPTV works as well Amazon Prime I don't have a strong argument with my ISP to request replace the modem/router.
  7. #27
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Here is a couple of Links to some info on setting up IPTV and Routers and wifi optimization etc.
    Worth a look for possible solutions!
    https://www.iptvinsider.com/improve-wifi-streaming/
    and
    ftp://files.dlink.com.au/products/DS...m_for_IPTV.pdf
    You will probably need the password for the router.
  8. #28
    Jun 2018
    Quote Originally Posted by kens View Post
    and
    Thank's ken, I'll check, on the other hand I'm not sure that the problem is in my modem/router because the IPTV works perfectly by 15 days and simply stop working.
  9. #29
    Jul 2015
    Mexico
    Quote Originally Posted by tonnynels View Post
    You might try lying to your isp tell them you are getting intermittent issues connecting to netflix (netflix has/had a 30 day free trial period) i had an issue with mine and it was the line from the street to the house, they replaced it and it's been fine since.
  10. #30
    Feb 2016
    yes i do -Y(not)
    Just FYI...
    Feeds from sites such as Amazon Prime, YouTube, etc., are not using the same .ts Transport Protocol.
    The protocol used is more like a file download and can therefore handle occasional data stream latency.
    The program you are watching will load fully in the background, whereas the .ts does not have this kind of large buffer capacity.
    The TV channel you are accessing is not stored on the Server, like YT or AP. It is sent out to a queue of users as addressed packets of data. If your ISP has a 250ms latency on 1 of the hops, well, too late... you have another packet or 2 addressed to you in the pipe.
    This format includes a synchronizing clock for the smooth decoding of Video and synchronizing to audio portions of the feed data.
    If the Next packet of data to be decoded is late, to the point of not keeping up with the Clock, you will have a glitch and the process then dumps their buffers, gathers the next few packets and starts the decoding process again.
    Now, depending on the speed of your processors, you can build up a playout buffer in your equipment of decoded and processed Video/Audio/Metadata info.
    HD has almost twice as much processing requirement as SD so this would relate to your Equipment capability to keep up.
    ...Oops!! Sorry, i'm rambling.
    I'll stop now!
  1. EPG is fully populated
    By MrPat in forum Dreamlink T2
    Last Post: 12-28-2017, 04:44 AM
  2. Five arrests in 'fully loaded' Kodi streaming box raids
    Last Post: 02-09-2017, 03:32 PM
  3. guide not fully updating
    By Justme in forum EPG (epg.ninja)
    Last Post: 04-26-2016, 12:16 AM
  4. Replies: 1
    Last Post: 11-09-2015, 02:46 PM
  5. Fully setup PAID NFPS working but few questions please.
    By sig1 in forum IPTV Private Server (NFPS)
    Last Post: 07-28-2015, 08:21 PM
