Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
  1. #31
    The logic here...
    "If you get the Message 'Your STB is Blocked, Call Provider', then your Server URL is NOT blocked."
    The service here sees your request but recognizes your device (browser) is not an approved device for streaming, so it rejects your request. Roughly translated: Your request reached the service here and had you been using a proper streaming device, you would have received the stream.
    "If you get an Error 404 or similar message, you are being blocked by ISP for that URL."
    Your request never reached the service here because something is blocking you. Roughly translated:. Even if you were using the proper device, you would not have received the stream because your request never reached the service here.
  2. #32
    Jun 2015
    US
    similar issues going on here for a few weeks now. all channels load and play normally for about 2-5 minutes then will timeout/freeze and ill get dropped back to the channel list. i can click the channel and it will play for another 3-5 minutes then timeout again. same sympton on both my ShieldTV and PC using latest kodi stable.
  3. #33
    See the following announcement...
    http://iptvtalk.net/showthread.php?3...l=1#post237322
  1. Many USA Channels Freezing and Looping
    By R2D2 in forum NFPS Channel Reports
    Last Post: 03-14-2021, 03:11 PM
  2. Channel Freezing and Looping every 2-3 minutes | For the past 2 weeks
    By Popeye in forum IPTV Private Server (IPTV66)
    Last Post: 01-14-2021, 05:17 PM
  3. Freezing looping
    By gino_1983 in forum IPTV Private Server (IPTV66)
    Last Post: 01-01-2019, 03:56 PM
  4. keeps freezing after 5 minutes of watching something
    By infectedtrut in forum IPTV Private Server (NFPS)
    Last Post: 04-12-2016, 06:56 PM
  5. IPTV freezing after 5 minutes - live TV Kodi
    By shapeup1 in forum Kodi Discussion
    Last Post: 12-22-2015, 03:28 PM
