Results 21 to 30 of 33
  1. #21
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    If using Kodi, check this Post ->http://iptvtalk.net/showthread.php?3...786#post236786
  2. #22
    Oct 2015
    Having same issue since this morning on my IPTV too... Seems like all US Channels are freezing, looping then going off...
  3. #23
    Member R2D2's Avatar
    Dec 2016
    Thanks Kens. Unfortunately, I've done this a long time ago. But good post for those that have buffering issues in general. Also, there are a couple repos out there that have wizards that auto create and config the Advancedsettings.xml based off your available memory. It's great...I haven't had buffering in years.
    Whatever the issue was, it seems to be fixed.
  4. #24
    Android World
    Thsi has been going on for 2 years already nothing new here.
    Lets Go !
  5. #25
    TV Junkie 1sikguy's Avatar
    Apr 2016
    Limbo
    Having same issues here on NFPS portal 3 … 05/26 2PM USA time
  6. #26
    Quote Originally Posted by trup111 View Post
    Nothing working, it’s been on and off, looping , sucks. Just shutt the damm thing. Looking for better service. This one is cheap but what good for.
    Truthfully it has gotten much better. There hasn't been downtime in months. Some of the channels are back to normal now too.
  7. #27
    Very few TV channels working for the last week - movies working fine.
    Tried IPTV reset several times, many reboots, left off for hours then reload, even software reload.
    Have a few news channels, weather and a few foreign channels.
    Any other ideas?
  8. #28
    Feb 2016
    yes i do -Y(not)
    Quote Originally Posted by snowman121 View Post
    Any other ideas?
    The working channels you mentioned are probably the open channels that always work (external URL's, not from Server)
    You are obviously not getting Authorization when attempting to watch the regular channels.
    Check your Donation is valid, shut down your system completely then do an IPTV Reset, then reboot your system.
    If you still don't connect, send a PM to a Moderator with your credential information.
    They will either be able to correct the problem or give you more info.
    *If you have changed anything with your ISP, this may cause problems also.
  9. #29
    Thanks for the reply!
    Donation is valid - over 250 days left.
    I have changed my ISP. I will try one more IPTV Reset, and if no luck, will PM a Moderator.
  10. #30
    Feb 2016
    yes i do -Y(not)
    Just to confirm you are not being blocked by your ISP, Enter your server /portal URL into a browser.
    If you get the Message "Your STB is Blocked, Call Provider", then your Server URL is NOT blocked.
    If you get an Error 404 or similar message, you are being blocked by ISP for that URL.
    *Also check that your ISP Lock is Off and Country Lock is On. (if ISP lock is on, you will not connect if you are using a new ISP).
  1. Many USA Channels Freezing and Looping
    By R2D2 in forum NFPS Channel Reports
    Last Post: 03-14-2021, 03:11 PM
  2. Channel Freezing and Looping every 2-3 minutes | For the past 2 weeks
    By Popeye in forum IPTV Private Server (IPTV66)
    Last Post: 01-14-2021, 05:17 PM
  3. Freezing looping
    By gino_1983 in forum IPTV Private Server (IPTV66)
    Last Post: 01-01-2019, 03:56 PM
  4. keeps freezing after 5 minutes of watching something
    By infectedtrut in forum IPTV Private Server (NFPS)
    Last Post: 04-12-2016, 06:56 PM
  5. IPTV freezing after 5 minutes - live TV Kodi
    By shapeup1 in forum Kodi Discussion
    Last Post: 12-22-2015, 03:28 PM
