Results 1 to 6 of 6
Thread: No Guide Info.
    Jan 2015
    No Guide Info.
    Anyone know what happened to the guide? It contains no information for any channels...
    Nov 2016
    Promise
    Getting the same thing here, I’ve waited about 30 mins to see if they load. No success
    Jan 2015
    Seems to be back up now, however very slow to load...
    Jan 2015
    Has anyone noticed that the guide is between 10 and 12 hours behind? Wonder what is casuing that?
    Nov 2016
    Promise
    Does anyone have a fix for the guide issue ? It’s been like this for a while now.
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Quote Originally Posted by 300turboz View Post
    I posted a solution a couple of days ago.
    Install Perfect Player
    Make a Custom Playlist file using the Templates in m3u section.
    Use my EPG guide URL.
    You use Perfect Player for TV watching, with a guide that is working as it should (the right time!).
    Only use DOL for access to VOD.
    * Just a workaround until they fix there problem.
  1. Replies: 2
    Last Post: 09-03-2016, 11:50 PM
  2. can't see the tv guide info
    By asesinopr in forum IPTV STB Emulators
    Last Post: 08-26-2016, 11:22 PM
  3. Server 4 guide issues on Avov (missing all uk channel guide info)
    By SebsiBC in forum IPTV Private Server (NFPS)
    Last Post: 04-19-2016, 07:56 PM
  4. Server 4 guide issues on Avov (missing all uk channel guide info)
    Last Post: 04-10-2016, 04:21 PM
  5. TV Guide info
    By cliff1946 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 08-04-2015, 04:26 PM
