Results 1 to 6 of 6
    Apr 2018
    T2 Overheating and Freezing Up
    I know that sounds like a contradiction! However, I find that when my T2 has been on for a few hours and has been busy during that time, it sometimes stops playing recorded material correctly, even though I know the recorded file is fine on the HD. And, sometimes the T2 just freezes completely and will not respond to the RC. On inspection, I found that the T2 box was getting very hot, especially on the underside, near the back. If I unplug it and leave it for half an hour, then plug it back in again, all seems to be fine. Does anyone else have a problem with overheating, and is this normal / expected behavior with this box?
    I put Plastic Caps from Milk Bottles under My STB to Raise it up a little for more Air Circulation and to keep it Cooler...! If You have a Spare USB Port, find a small fan to Suck the Hot Air Away from the Unit...! Just Ideas...!
    Ambassador
    Dec 2016
    I take the cover off all my boxes to allow them to cool better.
    Android World
    if your warranty is up i would open the box up and get a heat sink for all chips and put it down with some thermal paste.
    Lets Go !
    Nov 2016
    glue a cpu fan to the top .run it with a 9 vdc battery
    Apr 2018
    Just to say that I took Gallardo's advice, broke the seal and opened the box. I now run it with the component card sitting on top of the box instead of inside it! It has really done the tirck and runs much cooler now. I still have to reboot the box occasionally (once a week or so), but given that it's basically a tiny computer, that's not really too surprising. Anyway, all the freezing and non-responsiveness seems to have gone away since I opened it up. Thanks for the tip!
  1. Freezing freezing and onlt freezing
    By Bguanajua in forum IPTV Private Server (IPTV66)
    Last Post: 03-29-2020, 02:46 AM
  2. Is your box freezing? or how to make this freezing better?
    By hotwarmguy in forum IPTV Private Server (Rocket)
    Last Post: 01-31-2017, 03:21 AM
  3. freezing freezing all chanels freezing
    By FLOTADITO in forum IPTV Private Server (Rocket)
    Last Post: 07-02-2016, 03:27 PM
