Results 1 to 3 of 3
Thread: need help
    Apr 2018
    need help
    Got the box set up, got a server and up and running. No idea what I was doing and locked channels I wanted. Now can't get in anywhere as it says password required with no way to enter password? Any ideas what I done wrong and or how to fix.
    when is asks for password, enter 4 zeros thru the remote.
    Then when the channel appears, hit the Blue button to unlock it for next time. Do same for each locked channel.
    I think it is the blue button,.... (there is a Legend at the bottom of the screen to tell you what color button).
    I think you need to stay in the side bar EPG view mode, when doing this.
    How about a Factory Reset if all else Fails...?!?
