Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Feb 2017
    Thanks, I will try to reset.
    Mar 2018
    say yes i do
    same problem here, no portal connection, Dreamlink T1+, I reset modem, acc, and unit with no results, but it was the Id and Password, for some reason when the update loaded it went or change to a different ID and password, if you have the same problem just make sure that the information and Mac are correct, however this was the problem on my end and it was fixed by correcting the info,
    I also noted that:
    expire date does not show now and the channel numbers are all in different places they where before, like they used to be in the same as the other services and now is just all random, if anybody knows how to fix this please post, thank you.
    Simply exit the Portal (exit DreamOnline) and then re-neter again and that should get you connected.
    It works everytime here the same way.... First attempt fails but second attempt always connects.
    Should not have to reboot the receiver or router
    Android World
    same here portal is dead after t1 update
    Lets Go !
    Android World
    Do a iptv reset worked for me!
    Lets Go !
    Nov 2016
    Promise
    Any word on the guide, channel 300 now showing mlb. I tried the Channel group numbering that didn’t do anything. Dreamlink t1, with updates DOL2 app
    I'd head to the Dreamlink forums below to ask those kind of questions. You'll have a better chance of getting on target answers there.
    Feb 2017
    Resetting iptv worked for me. i unplugged the receiver for 15 to 20 minutes before i reset the iptv.
    had same problem. had to do a iptv reset .works ok now
  1. Upgrade from T1
    By Trupillo in forum Dreamlink T6
    Last Post: 03-03-2023, 12:07 AM
  2. since portal upgrade, cant get iptv
    By edwardnizz in forum PVR Clients
    Last Post: 03-27-2017, 08:51 PM
  3. Upgrade As Well?
    By Bkman2020 in forum IPTV Private Server (IPTV66)
    Last Post: 03-03-2017, 03:35 PM
  4. v2.4.0 Upgrade !!
    By montell in forum Dreamlink T1
    Last Post: 07-15-2016, 07:20 PM
  5. upgrade 8.0.4 to 9.0.21?
    By nelsonlfs in forum IPTV Stalker (Video add-on)
    Last Post: 10-27-2015, 08:34 PM
