Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Jan 2018
    Quote Originally Posted by guest View Post
    Thank you, so you don't have any ideas for a fix?
    So did clearing the cache work? (Sweeper). My buzz updates VOD fine even without clearing cache afaik.
    Quote Originally Posted by Aggy View Post
    Friend of mine was having some issues because he likes to leave his box on all the time. After little while his box started freeze and wont install or update apps…etc. I told him to reboot which he does not like to do and i told him there should be an option to kill apps or clear the cache. He said button next power kills apps. He tried and box started working fine without giving a reboot. Hopefully sweeper will work for OP as well. kof
    Jan 2018
    Quote Originally Posted by kingoffighter View Post
    That button next to power just clears cache afaik. Also Iike to actually close the live tv app by using the menu bottom instead of hitting the home or VOD button on the remote. Apparently if you don't close the live tv app completely it still uses data.
    i agree with you and that's how it should be done. Just exit out but my friend was just pressing home button and assuming app was closed. kof
    Banned
    Nov 2017
    in front of pc
    it is closed
    I know cause I can then use another box with same mac and connect to server
  1. Replies: 4
    Last Post: 10-25-2022, 08:06 PM
  2. NEW** OFFICIAL Update XR/XRS 4000 Update - Nov 17th-2021- FEEDBACK THREAD
    By NBS in forum BuzzTV XR/XRS4000 - XR/XRS4200
    Last Post: 11-23-2021, 01:46 AM
  3. Buzz box update (not Buzztv app update)
    By PayPerView in forum BuzzTV 3000 series models
    Last Post: 03-23-2020, 09:43 PM
  4. MAG 254 Update 2.18-r16 Feb 06 - Update 2.18-r17 - discussion thread
    By kingkong1 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 11-14-2017, 12:09 PM
