Results 1 to 10 of 16
Thread: Avov tv online
    Avov tv online
    Box wont update it has 1.0.2.0 also when you hit live tv to add p.s. it does noyhing Can anyone Help Please martys
    Donot know what you mean Thanks Merle
    Quote Originally Posted by martys View Post
    disconnect that Avov from internet, then disconnect power.
    Leave it like that for about 5 minutes.
    Then reconnect and see what kind of results you get.
    - Frank Zappa
    Mine shows this screen but difference no server setting Thanks martys
    you could try a couple other methods with that avov
    http://iptvtalk.net/showthread.php?2...323#post180323
    or find the WEB application in Your Apps or the Market
    WEB (TV.on.WEB Stalker Emulator)
    Version: 1.0.11
    - Frank Zappa
    No it shows storage usage& internal nothing Thanks martys
    Cannot post a picture I tried to reset by toothpick method and it wont update mine shows update 1.0.2.0 wont change to a new update is this the latest update Thanks for all the help martys
    THANKS for all your help I cant get any of this to work as build # is 1.0.20 and wont change also you said unplug hdmi cable if so how can you get a picture on tv martys
    With the TVOnline 4k model, the TVOnline app is not in the Apps menu.
    It does not need to be because the TVOnline app is embedded into the OS or guru.
    You will have a Play button which starts the app running.
    The pic of the menus which is posted above, is not the same as what you find on the 4k model.
    Which TVOnline avov model do you have ?
    As mentioned already... you do have options, depending...
    In your Apps or in the Market, is maybe the app called 'WEB' shown there ?
    That app will work with the MAC attached, similar to how the TVOnline app worked.
    Or use SimpleTV app or any other Player and thru m3u Playlist method,as per linked thread below.
    Version: 1.0.11
    - Frank Zappa
    Ok storage usage free space 935mb used 68 mb Also this build # is 1.0.20 model# avov-tlp Thanks martys
  1. Avov online n
    By ditchpig_99 in forum aVOV TVONLINE 4
    Last Post: 11-17-2017, 03:55 PM
  2. Avov Tv online n
    By leafs99 in forum AVOV IPTV Boxes
    Last Post: 07-14-2017, 10:54 PM
  3. Avov Tv-Online plus VS Avov TV-Online V2
    By floder2 in forum aVOV TvOnline+
    Last Post: 12-03-2015, 06:05 PM
  4. Avov Vixo 2 compared to Avov Tv Online+
    By ELEVO in forum aVOV TVOnline
    Last Post: 12-02-2015, 06:53 AM
  5. AVOV tv online
    By dixonsdodge in forum aVOV TvOnline+
    Last Post: 11-21-2015, 10:46 PM
