Results 1 to 8 of 8
    W3 Antenna Problem
    I got my W3 Antenna today for my Formuler z7+. I installed it in the USB3 connector and went to the wifi settings. I am running a duel mode NetGear NightHawk R7000 router on DD-WRT firmware. Upon checking for a 5G connection (I have one with several high end devices connected no problem), I see only 2.4G connections. I tested it on both my Formula and T2 boxes.
    Further to this post, I installed the W3 in a little ACER Netbook and it worked fine. The little blue light flashing and connected to my 5G WIFI connection so windows 10 had no problem.
    Any ideas other than it is defective?
    Copernicus Crater
    try other usb port. on those boxes theres a usb 2.0 and a usb 3.0 port
    maybe that will help
    Quote Originally Posted by Captainkangaroo View Post
    I did try that both on T2 and Formuler
    I have not got any to work on 5g
    Got the solution. A standard router sets the 5MHz to channel 153. I had my router set to auto and the W3 would not see the 5Mhz network. I set the Wireless channel to 149 and that sets it to all channels from 149 to 155. Once I did that the 5Mhz showed up in the Wifi list.
    Quote Originally Posted by profster View Post
    fantastic
    we gonna copy and sticky this post my freind , if you do not mind
    fantastic
    Not a problem that is what I like to do.
    Copernicus Crater
    Thanks, Good info....
  1. wi fi antenna
    By capthook in forum Dreamlink Dlite
    Last Post: 08-25-2019, 04:15 PM
  2. W3 Antenna Problem
    By profster in forum Formuler Z7 & Z7+
    Last Post: 03-25-2018, 08:11 AM
  3. Tv antenna
    By seafox62 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 11-21-2017, 10:56 AM
  4. 7db gain antenna for mag 254
    By motley22 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 05-24-2015, 01:51 AM
