They show you the ssid and password at front desk or in your room, look for it on your device should work.
Lets Go !
Without trying to add to the confusion.......if you have a box that has an internal or external antenna and has a Settings that you can scan for wireless networks, all you have to do is scan for the network, use the hotel password to log on and your box should connect without any other hardware. If you have a wifi scanner or device to find wireless networks, I would strongly recommend you use it BEFORE you check in to see what you can get for signal strength. Some hotels have really bad wifi with nothing more than a cheap 2.4ghz wifi system that will have a whole lot of issues with every microwave in the building. Dropped wifi packets will bring your freezing issues to a whole new level.
I've been lucky to be at some hotels that don't require internet password
hotels always keep 2 wifi logins one through there portal and one through there public wifi
Lets Go !
