Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 96
Thread: Freezing
  1. #51
    As I have Observed reading on this Fine Site, a VPN is OK if Used with KODI, FTMC and Other Means Possible but Not with TVOnline and the Stalker Method used to View anything from the Servers Talked about on this Fine Site...! That being said, There is Plenty to see in the KODI and FTMC Apps While using a VPN to Mask Your Location...! and You won't or Shouldn't get banned as long as the VPN is used Only with Them...! If I am Wrong then Please Elaborate...!
  2. #52
    Apr 2016
    Orziz!!! This dude might work on controlling the rocket server because he kept saying freezing is ISP problem.
  3. #53
    No, it just makes sense, since it is only happening to some people. Streaming is usually all or nothing. If some are getting it, usually all are getting it, unless there is some problem in between, like "tempermental routing," low bandwidth or an uncooperative ISP.
  4. #54
    Quote Originally Posted by ok489 View Post
    I'm almost positive it's an ISP problem
  5. #55
    Yes, in this case, an uncooperative ISP.
  6. #56
    Mar 2017
    Ok it could be the isp i had att changed my modem/router yesterday and still the same but these is my question this only happens after midday and while is happening all the others channels work great the international channels except the sky and American channels but Americans channels in Spanish works good too now i been doing some reading and you can buy a router and bypass the att router do you think that will make any difference
  7. #57
    Apr 2016
    Explain to me why under MOVIECLUB, Not a single freeze on every movie any time; but under TV most channels were freezed especially US channels starting around 10am to around 11pm???? If it is ISP problem, both should be freezed because "MOVIECLUB" and "TV" are from Rocket.
  8. #58
    When You want to watch a Movie and Click it, do You see it Loading...?!? It is on another set-up altogether...! Once it gets Loaded, it is Loaded which means it is no longer Streamed but d/l'd to Your STB and waiting to be seen without Interruption...!
  9. #59
    I do not know if it has been said earlier in the thread because I have not read all 6 pages, but if you are on DSL (ADSL) then the further away you are from the booster the slower you are and of course the more connections their are between you. The more that can demand service at the same time. This can and does cause a delay in your packets reaching your modem. Another thing to keep in mind is if using wifi the more people close to you can cause wifi interference between your box and your router.
  10. #60
    They come from a different source than the channels, and the internet provider is not buffering those streams.
  1. Freezing freezing and onlt freezing
    By Bguanajua in forum IPTV Private Server (IPTV66)
    Last Post: 03-29-2020, 02:46 AM
  2. Is your box freezing? or how to make this freezing better?
    By hotwarmguy in forum IPTV Private Server (Rocket)
    Last Post: 01-31-2017, 03:21 AM
  3. freezing freezing all chanels freezing
    By FLOTADITO in forum IPTV Private Server (Rocket)
    Last Post: 07-02-2016, 03:27 PM
