Results 1 to 7 of 7
    Apr 2015
    T2 and dlite having audio issues
    Dl t2 and dlite dropping audio to zero volume on most channel's on certain servers. When audio goes to zero i walked by avov playing the same channel and audio is fine.
    After playing a channe forl minute or so audio drops to mute , then after couple seconds audio comes back. Its keep happening non stop...
    Got feedback from multiple dreamlink owners and all are having the same issues.
    No such problems with my DLite.....
    Quote Originally Posted by desiboy1 View Post
    try to reset one of the box and see if that helps. if it does then you know what to do with second box as well
    Apr 2015
    Had to install audio codec. Thanks
    good to hear that. thanks
    Mar 2018
    how do you install Audio codec ?
    Not sure what you mean by reset the box??
    Copernicus Crater
    Quote Originally Posted by BobLo View Post
    Off the top of my head, open Addon Linker, find Audio Codec Pack.Zip, click to install
    To reset: Open Settings,System,Factory Reset
  1. Replies: 133
    Last Post: 01-18-2018, 03:09 AM
  2. Replies: 105
    Last Post: 01-10-2018, 01:30 AM
  3. Replies: 102
    Last Post: 12-27-2017, 04:43 PM
  4. T1 audio issues
    By regional in forum Dreamlink T1
    Last Post: 06-30-2017, 03:44 PM
  5. Audio Issues Mag 254
    By 33458 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 05-19-2016, 12:37 AM
