AVOV rear button Factory Reset by D.M.
1) Unplug the power from your device but keep the HDMI in.
2) Get a bent paper clip or something to press and hold the small reset button next to the power jack on the back of your box.
3) With the power unplugged hold the reset button for 10 seconds and while holding the button down, put the power plug back in.
4) Continue to hold the button for another 5 seconds and then let go of the button.
5) The box will reboot into console mode and from here you will select the 5th blue line down that says “wipe data/factory reset”.
6) Next you will need to select the blue line that says “Yes – delete all user data”.
7) Next you will needs to select the blue line that says “reboot system now”
8) Your box will reboot to the original factory condition and you can begin re-entering all your required settings etc.
