Results 1 to 6 of 6
Thread: web ?
    i do
    web ?
    ok. since I can no longer connect to the rocket...
    I've done the factory reset, reset. the Mac an the other I forget what its called
    so far nothing
    so I downloaded the web program an cannot get any further then the server screen all I can get is the url underlined in red.
    I've tried the short version an the long one tried with 3 forward slashes after the html code tried with 2still same result
    anyone have. ideas/?
    avov online plus
    txs
    Is the SimpleTV app in your market and available?
    If so then try that.
    You would delete the MAC from the website and leave it deleted, and then get a PLaylist from the server website and use that Playlist thru a USB device drive or thru the Playlist's URL with the SimpleTV app (Player).
    The best advise anyone here can give you is to get a new box. AVOV as a company is crap, and the Online/Online + are so outdated they're not worth keeping.
    If you insist on using it with Rocket, download Simple IPTV from the market. This is a playlist IPTV app. You can download the playlist from Rocket and put it on a USB stick and load the list into Simple IPTV and it should work for you.
    i do
    thanks. but I don't see it here, just a program called simple iptv
    is it time to get rid of this box?
    i do
    Quote Originally Posted by PayPerView View Post
    no I. don't care about avov. I just like it simple any recc?
    The best advise anyone here can give you is to get a new box. AVOV as a company is crap, and the Online/Online + are so outdated they're not worth keeping. .
    Those have anyway stopped working with recent updates, not sure what is going on !
    Devices Owned: Apple TV 4, Dreamlink T1, Dreamlink T1 Plus, Dreamlink Dlite, Dreamlink T2, Formuler Z7+, AVOV, MAG 254, MAG 256, Mag 322, Buzz XPL 2000, Buzz XPL 3000
