Hello,
Can some one help to remote TV program , I have SONY 4K TV and try to program STB retore with my TV, Please can some one provide TV code or fhow to program.
Thanks in advance.
Hello,
Thanks in advance.
usually written instruction comes back side of the remote control.
im trying to upload
its not working for me
try this. search link with google. its for t1 but im sure its same for t2 as well. kofCode:*************************wp-content/uploads/2017/03/How-to-program-dreamlink-T1-remote-control.pdf
if that does not work then may be you want look into Logitech Harmony. Logitech Harmony remote control works fine.
Thanks for information, but still not program remote.
Do you have code ?
TV / Source Button Programming;
1. Press and hold [TV] for 5 seconds. The LED goes from blinking to solid
and STB Remote Control Unit will enter Learning Mode.
2. Press the Key to be programmed on T1 plus Remote Control Unit. LED
begins blinking slowly.
The key is now ready to accept programming.
3. Aim the TV Remote Control Unit towards the front of the Dreamlink T1
plus Remote Control Unit (the distance must be less than 3cm).
Press the button on the TV Remote control. If the T1 plus Remote Control
is programmed correctly, the LED will flash 3 times.
4. Repeat step 2-3 for other keys.
5. Exit Learning Mode by pressing any other button on the Dreamlink T1
Plus Remote Control. LED turns off.
