Results 11 to 20 of 33
Thread: lost epg
    The URL is still .tv. You'll need to reconfigure with that in mind. The guide is working.
    Jan 2018
    ON, CAN - testing for 20 years
    Thank you so much for this post. I was going nuts all week trying to figure out why my guide stopped working. I used the link mentioned in the post above, cleared the data fields in KODI and it worked! I never had to delete any files.
    Thanks again!
    Happy to hear you're back in gear
    Thanks for your help Ilan. I have done the reconfiguration of pvr Stalker Client using "tv" and even an iptv reset. However when I open Kodi I still get the 'Stalker Client unable to load channels" error and of course no guide. I am at a complete loss as to what to do next! Any suggestions as to what I might try? Using Kodi 17.6. Thanks in advance.
    If you are using the short portal URL, try using the longer one. Make sure the URL is typed accurately. There is always the posibility that your ISP is blocking the URL. Kodi is reporting that it is not receiving a channel list. This has nothing to do with channels not authenticating. If you paste the URL that you are using into your browser, do you get some form of response from the server?
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Quote Originally Posted by vtaylor1229 View Post
    Check the setup instructions to make sure you have not missed something
    http://iptvtalk.net/showthread.php?29584-Kodi-Version-17-and-above-PVR-Stalker-Client-Setup-Instructions
    * The guide URL in the Instructions is no longer viable (I tried to change it but the system wont let me edit)
    Use a different guide URL.
    Any changes to your PVR Settings requires you to Disable the PVR, then go to System Settings/ PVR&LiveTV/ General tab - Clear Data
    Shutdown Kodi, go to your Donation page and do an IPTV Reset.
    Start Kodi and go to System Settings/ Addons/ My Addons/ PVR Clients/ Stalker Client - Click Enable.
    Not following this procedure will leave old info in the Server cache or Kodi's cache.
    When I paste the URL I am using into my browser I get the following:
    "Your STB is not supported.
    (a red dot) Reload Portal (a yellow dot) Account Info (a blue dot) Payment"
    (PS I am NOT using an STB!)
    Quote Originally Posted by kens View Post
    Thanks Kens, but over the last several days I have repeated that procedure many times. However I did it again just now and got the same results. This is what happens. When I enable PVR Stalker Client, the channel list loads, but not the guide. If I now restart Kodi, I get the Stalker error again about being unable to load the channel list! When I disable and then enable the PVR and restart Kodi, the channel list loads, but if I now or later restart Kodi, I get the error again!
    It means your ISP is not blocking the server. If I had known the channels load, as you mentioned in the subsequent post, I wouldn't have bothered with this step.
    Feb 2016
    yes i do -Y(not)
    Go to System Settings/ PVR&LiveTV/ Guide- Enable "Dont Cache in Local Database.
    Clear your data again.
    (*also make sure your connection timeout in Stalker settings is set to 60 or above)
  1. lost epg
    By everton in forum BuzzTV 3000 series models
    Last Post: 01-14-2018, 09:44 AM
  2. A bit lost
    By Fyldeblue in forum New to IPTVTalk
    Last Post: 01-01-2018, 11:59 AM
  3. Im lost
    By ditchpig_99 in forum Android Devices
    Last Post: 02-28-2017, 11:28 PM
  4. WTF i have never been so lost
    By mr tripps in forum EPG
    Last Post: 12-09-2016, 12:56 AM
  5. I am lost
    By Jamiebanks in forum PVR Clients
    Last Post: 03-05-2016, 11:14 PM
