I don't have this particular unit but I had a bunch of other boxes of all type and fusion installer always work for me.
look everyone has right to say what they think but know what your talking about first imoa
Try a different usb stick...........
look first format it to fat 32 on your stick and use a zip file and yes try i different usb and do you know how to add fusion installer or total
Just to add this experience with my VIXO1, if adding a USB stick/drive to run local media the drive doesn't show in local media until I reboot my box. Even though it's showing the USB symbol in top left corner between the WiFi and Ethernet symbols.
Yes.....Try using addon installer tool...or fusion and then you won't have to worry about the usb stick...By the way your unbiased review sounds very biased to me..
why the h-- not really im sorry do you know how to run kodi add source click ok a kb comes up to add url
just use addon installer tool...or fusion and be done with it.....very simple...You will have all the repositories available....
