kcos54
Lets say you have sports devil addon in a zip file on your usb flash drive..Tell me how you are trying to install that to Kodi on the Avov2
In Kodi-- system, setting, add-ons, install from zip file, root file system, then where the sdcard and storage is listed the USB should show and it doesn't but on my other system it does?? My PC shows and I tried a zip file and it didn't work , I will try a different repo.
It's running Kodi Isengard 15.0 beta ?? It's the new Kodi maybe that's why??
Not ROOT ..look for Udisk0...that should be your usb
kcos54
You should now post back and tell us how simple that was when you do it correctly ................
look at you you dont know anything about the new box or how to run it if some one need to tell you the basic how to load a file then im sorry an My unbiased opinion you dont know anything
hmmm....post and run..oh well..
OK wiz then tell me how, here is a picture and what my options are.
External Storage --- NO USB or Udisk0
Internal - SD ------ NO USB or Udisk0
Root filesystem ----- NO USB or Udisk0
I also went in to each of these and click on everything and NO USB OR Udisk0IMG_20150527_112126.jpg
