is there any other way to do this?? I did get it downloaded to a sd card but when I go to unzip it it says failed to load!!
HELP??
HELP??
something here
think kodi is blocking porn
Lets Go !
this is what I get when I go to unzip the file---plugin_video_videodevil_1_7_163.ZIP>ZIP and when I click
it on it says up in the right Corner failed to install from zip file--any thoughts on this??
something here
just noticed when I take the SD card out of the box the video devil does not appear in the file manager--
or when I go to install from the zip file it doesn't appear there either. Does this sound right or am I
missing something.
something here
I like your answer, but I would like to get this G.D. thing working any adult on stalker client???
something here
I highly suggest not using the Stalker Client for Kodi. You could go the 'playlist method' not using the MAC authentication, and use the PVR simple client using Potato TV, and you will see Adults, if you so desire. Chasing 5 or 6 Adult channels on the supported servers that aren't natively streamed isn't really worth it, especially with all the free stuff using VideoDevil, IMO.
I may be wrong as I haven't tested the Stalker Client in a very long time, but the developer didn't code for the way the servers did its parental controls.
Thanks to everyone for your help! I don't know hoe but I finally got it!
Thanks again
something here
See that... You're watching so much porn that you're beginning to substitute porn words (hoe) for standard English. Woe be the day!
