Results 11 to 20 of 22
Thread: Simple IPTV EPG
    Oct 2015
    If kens guide works with simple iptv app with mx player app on the dreamlink t6, id love to try it. I just dont know how or where in the app i would put kens url.
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Quote Originally Posted by ADP0361 View Post
    Kens, just wanted to say thanks for the guide you provide. Just great, and works on every possible app. Perfect Player, and even the new ProgTV guide. Really appreciate you sharing.
    You are very welcome.
    Feb 2016
    yes i do -Y(not)
    Quote Originally Posted by jeep91 View Post
    I tried Simple IPTV, when I was testing various apps.
    As far as I remember, there is noe EPG capabilities (It may show channel list & info, just cant remember).
    If you want a very good stand-alone Android program with a full EPG, use Perfect Player instead of Simple. You wont regret it.
    here is a link to a tutorial video -> http://www.mediafire.com/file/nt5p5d...S_Tutorial.mp4
    Oct 2015
    Downloaded perfect player unto usb and went to app installer in programs but it doesn't see pp on there to install on the t6. Is there another way to install on t6? Also tried es file browser but it asks how i want to download cideo, Music etc.. but then get error message of file not correct.
    Feb 2016
    yes i do -Y(not)
    Android settings/Security - Allow unknown sources.
    Oct 2015
    Ok will try. It does show other apps though on the usb just not pp.
    Oct 2015
    So looks like its already checked.
    Oct 2015
    Finally got pp to install. I had previously downloaded the exe file not the apk. So now i got epg going. Tje problem now is that many channels video is slow. The audio is fine and its not that it freezes but more of a lag. Any suggestions?
    Feb 2016
    yes i do -Y(not)
    In settings/ playback - Decoder set to Software or Native.
    This setting is very dependent on the platform.
    Try them all.
    Oct 2015
    Ok. Its on software right now. I will try native. It works quite smoothly on smartphone. Just on the t6 it lags. On simple iptv though on the t6 also no lag.
  1. Replies: 1
    Last Post: 05-11-2016, 12:47 AM
  2. Replies: 340
    Last Post: 10-28-2015, 12:30 AM
  3. Replies: 2
    Last Post: 07-21-2015, 05:24 PM
  4. Replies: 2
    Last Post: 07-01-2015, 04:59 PM
  5. Replies: 2
    Last Post: 06-28-2015, 01:11 AM
