Results 1 to 4 of 4
    Dec 2016
    Kodi Real Debrid Surround Sound
    Ok folks a better mind would help. I can't seem to successfully enable surround sound. Have an Onkyo tx nr709 receiver. I enable passthrough in my kodi and have no success playing back 5.1 streams with audio all I get is a cutting in and out of hissing audio. When I un select passthrough I get audio but it's not digital if I'm correct. My receiver will only ever show pcm and does not change to digital after selecting enable passthrough and as I said I get just hissing audio with my amp still stating pcm. I hope I've made this understandable. Please help me out.
    we have no control over that need pm them
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    I'm not sure but I don't think 5.1 is encoded in the Data stream of IPTV.
    For other sources
    How to Setup Real Debrid in Kodi Jarvis:
    Select SYSTEM
    Select Add-ons
    Select System
    Select Dependencies
    Select URLResolver
    Select Configure
    Select Universal Resolvers
    Scroll down to Real-Debrid
    Select Priority
    Change priority to 90 and select Done
    Select OK to save your changes (we need to do this before authorising otherwise the changes may not save)
    Select Configure (again)
    Select (Re)Authorize My Account
    You will now get a popup asking you to go to the Real Debrid website
    Open a web browser on your device (or your phone/computer or anything) and go to https://real-debrid.com/device (you must be logged into Real Debrid for this to work) and enter the code and select Continue
    You should now see a popup telling you that your account is authorised
    Real Debrid is now setup
    Krypton is basically the same, but with the different default skin.
    Go here for more info -> https://seo-michael.co.uk/how-to-con...ebrid-in-kodi/
    Real-Debrid is pay site which we have nothing to do with
  1. DD (Surround Sound)
    By Spanner in forum Kodi Discussion
    Last Post: 07-03-2017, 04:47 PM
  2. HDTV and DD (Surround Sound)
    By Spanner in forum aVOV TVONLINE 4
    Last Post: 02-02-2017, 01:57 PM
  3. surround sound
    By dontony in forum Chit Chat Lounge
    Last Post: 08-17-2016, 08:06 PM
  4. vpn or real-debrid account
    By gregm in forum Kodi Discussion
    Last Post: 06-27-2016, 11:24 PM
  5. MXQ Surround Sound Issue
    By zaidorade in forum Android TV Boxes
    Last Post: 06-09-2016, 04:29 PM
