Hello All,
DL T1 Plus is working fine. Updated and running Kodi perfectly.
The only issue I have noticed is that when I press the up and down arrows on my remote, it makes my HDMI switcher in the living room switch inputs. The next thing I noticed is that when I press the Exit button and the upper remote control functions (play, stop, etc.) the DL remote turns on, off, bluetooth scan on my Vizio sound bar. In IPTV, you regularly use basic functions, but if you are in Kodi watching movies and all and want to stop and play, this is frustrating as the Dreamlink remote is messing with several equipment's.
I would have expected Dreamlink to have their own unique IR codes to not mess with other equipment in the room... Never had an issue with any other FTA boxes I have played with.
This is something that I don't even know how it can be fixed. An update won't do anything as the IR signals being sent are coming from the remote...
The only workaround I have seen is to use the old dreamlink HD remote (no issues at all). The dreamlink t1 plus remote messes with everything.
Any ideas?
