Results 1 to 6 of 6
    Oct 2015
    guide 3 hrs behind
    Not sure if its my set up in potato but guide is showing shows that are 3 hours later
    set up time zone for new York , it is giving the right time of day though?
    must be something with the guide pulling info
    what should be in the epg source in potato,,, viper still ?
    I am using kens modded Template stuffed kensguide TV Eng 1017.m3u and hxxps://raw.githubusercontent.com/kens13/epg/master/guide_kens.xml
    Are you using Potato with IPTV Simple client? If so, it doesn't matter what you have in Potato TV as long as the working guide is specified in IPTV Simple client. There is a time offset in IPTV Simple client to deal with time discrepancies.
    Oct 2015
    Yes i am using that setup. I just tried to take 3 hrs off in iptv simple client but no go,, ill just have to keep playing with the setting in iptv simple
    Thank you
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Check your systems timezone setting
    Also any setting changes require you to disable the pvr, clear your data cache in liveTV settings, then re-enable the PVR.
    Oct 2015
    got it worked out,,, went into simple iptv and manually set it for -5,,, all good now
    Good to hear
  1. Replies: 2
    Last Post: 09-03-2016, 11:50 PM
  2. Server 4 guide issues on Avov (missing all uk channel guide info)
    By SebsiBC in forum IPTV Private Server (NFPS)
    Last Post: 04-19-2016, 07:56 PM
  3. Guide stop working channels work no guide
    By Tata123 in forum PVR Clients
    Last Post: 04-12-2016, 02:27 AM
  4. Server 4 guide issues on Avov (missing all uk channel guide info)
    Last Post: 04-10-2016, 04:21 PM
  5. Stalker Client 0.8.3 and EPG Guide Program Guide Time Issue
    By MitchL in forum IPTV Private Server (NFPS)
    Last Post: 10-17-2015, 01:57 PM
