Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: DL T6 and IPTV
    Oct 2015
    DL T6 and IPTV
    Tried following instructions to get the emulator going on the t6 to get iptv. Im a bit confused though. I get blue screen and message server not found or something. Also , when configuring in profile i dont see where to put donation number. I have t6 with kodi 15 on it. Iks was working but gone now. I want to switch to iptv. I feel very lost have read alot but still confused how to get iptv going. Am i supposed to try a stalker client app or pvr or something? Any help is greatly appreciated.
    that T6 is a bit touchy when it comes to the emulator installation.
    I think if you click on either upper corner of the screen is where them hidden functions are found.
    But there is another way that you can use your T6 with iptv... and that is with a an M3U Playlist
    Check the link below for a how to on that.
    http://iptvtalk.net/showthread.php?2...n-M3U-Playlist
    If any trouble please do not hesitate to post back here.
    For instance, if you can not find that Playlist Player or what ever the issue may be.
    Oct 2015
    Thanks a mill. I read through it and was wondering ...i have nfps donation and it says iptv 66 or rocket. Will it work with nfps and where do i go to create the account? Thanks again
    yup, nfps will work same.
    I wrote that tutorial before NFPS went with the addition of the m3u format, but they followed suit shortly after I posted that.
    http://iptvprivateserver.is/
    Oct 2015
    Oh, also i just noticed in email when donation was sent that there is no 16 digit order number. Just the 12 digit don and other items. Am i missing something?
    Quote Originally Posted by jeep91 View Post
    did you buy from a private guy or direct from that iptvprivateserver.is site ?
    If from a reseller(private guy), he should have given you a Client ID that replaced that 16 digit order number. He can not give you the order number because he may have many clients on that same order and he does not want his clients able to see his full order.
    You can also click on my name and send me a private message with that donation number and I can find either that order number or your client ID for you.
    * and I fixed the tutorial to show NFPS as well.
    Thnx for the heads up on that
    Oct 2015
    clicked on name but not getting option to send message. Maybe cuz on mobile phone?
    yes, that mobile phone will not have the message option.
    But I will send you a message and that way it may appear on your screen and you may be able to use that to access the message and return a message to me.... otherwise you will have to get to a PC or laptop.
    sending message now
    Oct 2015
    Sent it. Hope i did it right..
    yup, I received it.
    And it is as I suspected. You purchased from a private sale.
    I can not give you the 16 digit order number because he has approx 50 clients on that same order number, so I can not betray his trust.
    But I can give you the Client ID and you can use that in place of the order number.
    I tried it at the website with the Client ID and 12 digit donation number and does work to open your code
    I sent you back a message again with the needed Client ID
  1. Replies: 1
    Last Post: 05-11-2016, 12:47 AM
  2. Replies: 1
    Last Post: 01-18-2016, 06:15 PM
  3. Replies: 2
    Last Post: 07-21-2015, 05:24 PM
  4. Replies: 2
    Last Post: 07-01-2015, 04:59 PM
