- Frank Zappa
my shuts down and goes to the app, and also I still have problems with voice and videos wish things would work right, I have never had so much problems with a receiver I owned before.
Uninstall DOL and Re-install and that might fix your problem. The DOL should be the current build
My power button on the remote will not power the T1 on anymore since the update. But it will power it off.
I am also confirming the same issue observed. Will try to uninstall and re-install to see if it helps.
After firmware update, dream link t1 acting up , starts in apps or in settings , not recognize wifi and does not connect to live tv.
Mine also keeps disconnecting or buffers real bad since the update
Hopefully we get the fix soon.
