My opinion is still use the box mac..which did you link and where did you purchase your box...
I would also upgrade to 218r11 if you haven't...
I tried both and I purchased my box from A Romanian Dealer in New Jersey
Firmware has been updated.
then the only thing is you have the wrong url check it if your not up should be what are you using
at the present time I have only linked my avov, my mag254 is unlinked and working fine on the service right now...
Ok I will Check Url: the Url is http://1.iptvprivateserver.tv
Then I guess my best bet is to unlink my Mac Address if no link is working fine right now?
sorry getting that too hold off for sec
yea i would do the mac address and id try that i will do the same and see if it works again sorry up on the avov on all boxes
