I just turned on my mag 254 and it is giving Authentication problem? I Used the same Mac Address that it gives me when I choose my Network info in system settings.....should I load my routers Mac address instead?
Respectfully,
wkproctor
Respectfully,
wkproctor
the box mac is correct...
Then why is it giving Authentication Problem?
it could very well be someone using stalker client or stb emu has used that mac and is logged in...we were just down for awhile so I suggest you try again and reboot entire system. modem/router and box, thks
Thank you very much
welcome....
The device info shows a different Mac Address then the Mac Address in System/Network Info/ current status screen.... I have tried both but neither cleared the authentication problem error.
so I assume you're running wireless??
we were down the time you were asking all should be good now
Yes I am using wireless
