Results 1 to 6 of 6
    Strange Problem with MAG 254 Remote
    Recently I have noticed a strange issue with the MAG 254 remote. This has happened at different locations. The power button light (red) flashes continuously for a while, stops and then the remote goes dead. I put in new batteries, but the remote does not respond. Anyone else has had this experience? This has happened with used remotes, and a brand new remote as well. Any ideas?
    Nov 2017
    Hello. I have exactly the same probleme . Did you fix this problème ?
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    This is a no-brainer suggestion but... increase the tension on the battery contacts.
    Worth a try!!
    Nov 2017
    no man this is not a remote problem cause i used another remote and still the same probleme
    Nov 2017
    Dec 2017
    Try another HDMI cable or Press SETUP and OK button at same time and hold for 2 seconds red LED will flash 5times. Reset is done.
  1. BuzzTV XPL 3000 problem with the remote
    By Javier_11 in forum BuzzTV 3000 series models
    Last Post: 12-25-2022, 08:36 PM
  2. Strange problem
    By skybound in forum Dreamlink Dlite
    Last Post: 11-16-2018, 02:57 AM
  3. Strange Problem with Mag254
    By artvan in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 06-29-2017, 01:25 PM
  4. Mag 254 Remote problem
    By sam240 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 11-28-2016, 10:51 AM
  5. Mag 254 remote control problem
    By geevee in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 06-10-2016, 05:00 PM
