Results 21 to 30 of 37
  1. #21
    I have a question, are you using the dns that your isp provides or are you using one of the following, 8.8.8.8 -or- 8.8.4.4?
  2. #22
    yes I do
    the one isp provides
  3. #23
    crazybobs TV Expert
    To test if Your ISP Has Blocked the p1.iptvrocket.tv - type it in your browser. If it times out and provides and error Then it is BLOCKED. If you see a message "Your STB is not supported" with a Blue Background then You are Not Blocked. Please Rocket issue a new URL
  4. #24
    yes I do
    I get -
    Hmm, we can't reach this page.
    Try this
    Make sure you’ve got the right web address: http://p1.iptvrocket.tv
  5. #25
    crazybobs TV Expert
    Quote Originally Posted by redskins View Post
    I get -
    Try this
    Your ISP have Blocked The URL http://p1.iptvrocket.tv/c/index.html. We need to get NEW URL's From Rocket - Rocket Does Not Want people Using VPN's . If you were Not Blocked You would go to a Site with a blue back drop the states "Your STB is not supported" in other words a Live Site
  6. #26
    Change your DNS in your router to the 8.8.8.8 or the 8.8.4.4. This will let your box use these DNS's and you may get the box to start playing. Blocking us usually a function of the DNS not replying with the isp you need. The DNS locations I listed belong to Google and were sometimes encouraged to use in IKS because of a faster responce time than the local servers, which probably were sharing with other sites and causing more hops, which was a time factor in IKS.
  7. #27
    crazybobs TV Expert
    Quote Originally Posted by Lowteck View Post
    I have done this and all my routers have had primary DNS To 8.8.8.8 And Secondary to 8.8.4.4. For years now. The URL is BLOCKED by the ISP. The only way I can get them unblocked is to change a digit in the MAC Address and for the Public IP change which only lasts for a week. I know others who Can Not do this because they use ISP provided Modem/Router Combinations.
  8. #28
    Jan 2017
    Yea
    I have been having the same problem with my Avakn box since three weeks ago.. I brought a new box it's not working I switch over to new box is not working... Change so many URL not working... Now they said your box is block.. Can someone help me I'm so tired of this.
  9. #29
    crazybobs TV Expert
    Quote Originally Posted by Gabfinley View Post
    what service do you use ???
  10. #30
    get active,bitch Bandit5906's Avatar
    How about just IP Release, ip Renew?
  1. STB block
    By gedeguone in forum New to IPTVTalk
    Last Post: 04-07-2018, 10:42 PM
  2. my box is down can anybody help new kid in the block
    By ldragon in forum New to IPTVTalk
    Last Post: 01-24-2018, 05:44 PM
  3. STB block
    By Mag4rob in forum Introduce Yourself
    Last Post: 08-31-2017, 05:47 PM
  4. New kid on the block
    By Sirlord in forum Introduce Yourself
    Last Post: 01-16-2016, 04:38 AM
  5. New boy on the block
    By IPTVN3wb in forum Introduce Yourself
    Last Post: 10-13-2015, 04:07 AM
