Page 3 of 34 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 336
  1. #21
    PWA aCiDjEsUs's Avatar
    Jun 2015
    On a mote of dust suspended in a sunbeam...
    Quote Originally Posted by space_114 View Post
    Nope ... No go for me either ... Cleared cache and guide info ... Restarted Kodi ... all my preferences seem correct as indicated above ...Still no go .... If anyone fiqures this one out please post your resolve. Thanks ...
    Try to delete the epgxmltv.xml file which is located:
    SYSTEM->File Manager->Profile Directory->addon_data and then you'll have to choose either pvr.stalker or pvr.iptvsimple after selecting one delete the epgxmltv.xml file restart Kodi and the guide should load without issues.
  2. #22
    Jun 2015
    Quote Originally Posted by expatter View Post
    Since a few people seemed to be having trouble loading your guide I thought I would give it a try. If I load it in a browser it does seem to take a very long time to load, but it loaded up fine for me in my Simple Client PVR.
    Great job on your guide, it's nice and full!
    When it did finally load in a browser I noticed a few channels that need to be tweaked in your ren file:
    I285.65342.schedulesdirect.org:Investigation Discovery HD
    I286.60468.schedulesdirect.orgestination America HD
    IWatch.61458.schedulesdirect.org:Watch (here's another one for that channel: I245.61458.schedulesdirect.org:Watch
    I565.46710.schedulesdirect.org:Hallmark Movies & Mysteries HD
    I312.11221.schedulesdirect.org:Hallmark HD
    I333.14873.schedulesdirect.org:IFC HD
    I557.16108.schedulesdirect.org:Sundance HD
    Thank you Ex, I had some issues loading guide for those specific channels that's why there is a small mess in my ren file. But will get on that. Thank you buddy.
  3. #23
    Jun 2015
    Quote Originally Posted by Tack View Post
    Acid, just curious - what lineup do you use for the UK channels? I pull mine from BSkyB but the BT Sport channels are not listed.
    BTW, yours is not loading for me either now (times out) although it worked fine a few days ago. It looks like server overload.
    Edit: Duh, asking the question made me look again. I was pulling from BSkyB England instead of BSkyB UK.
    Tack I'm using BSkyB - England (United Kingdom)
  4. #24
    Jun 2015
    As I mentioned in another thread, there could be some server, bandwidth or simulateous download issues, but I have no way to determine that. For those not getting it to load yet, leave it configured and bide some time. I suspect the guide will eventually populate. You can try data clears and restarts, but it might just be the luck of the draw that dictates success.
    I have no way of checking that, I'm using hostinger's premium account which I payed for few days ago and should be unlimited bandwidth etc.
  5. #25
    Jul 2015
    yes i do.
    Thank you my 2 guide sources have been down for about a month , People Read Forum you will find the answer to your questions 99% of the time , Thank You
  6. #26
    Oct 2015
    Yes I do
    Been trying for couple days now to bring guide up no luck,using stalker client and kodi 16.1 was using yahyabell with no problems and have tried couple dozen times to clear guide and reset as well. I have entered http://acidjesus.tk/guide.xm1. Have rebooted serval times and each time I clear guide I do a restart, also let it sit for couple days thinking it might populate on its own..anything else I could try guys please let me know...thanks
  7. #27
    It is an L at the end of XML, not a 1.
    XML stands for eXtensible Markup ​Language
  8. #28
    Oct 2015
    Yes I do
    Thanks Ilan just changed that and had tried it as an L couple days back with no luck so changed back to the 1..... lol...anyhow did cleared guide a couple of times and restart but not populating yet..will let it sit for awhile and hope it works...
  9. #29
    The 1 would get you nowhere fast. Keep it as an L, and it will populate fairly soon.
  10. #30
    Nov 2016
    Epg
    Just wondering did viper take his guide offline.
Tags for this Thread
