Page 23 of 34 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 336
  1. #221
    so the problem is really _ if you remove that you will get epg but no categories.
  2. #222
    that dash or 'underline score' prolly works as a 'directive' type thing. Everything after the dash is included in the directive. But without the dash, then nothing else is seen after where the dash was .. or something like that maybe
    thats is correct. so its something probably in software requires a bit adjustment maybe
  4. #224
    can I start called you by the name of Detective Ryu ?
    Cause I think you are getting close to the meat of things.
    Let's hope the Buzz team will see that too.
    Something else to consider....
    if I use the server EPG URL in that same m3u slot, and with the complete Playlist URL, I do get population and icons and categories and etc.
    Server EPG URL (unique to user's portal and credentials)
    http://PORTAL:80/xmltv.php?username=xxxxxxxxxxxx&password=xxxxxxxxxxxx
    detective or anything bro no worries lol
    so whats the difference between servers and acids epg?
  6. #226
    server's epg is embedded/accessed thru port 80 (to server) while acid's is accessed thru github
    Unless something changed in acid's pushes and pulls... but according to Harry Balls from other site this issue started awhile ago and Joker sorta concurs with that except an update to his x5 disrupted it all.
    And me, well damn, i never really know what the heck I am doing .
    beside that is theres anything difference? I mean does acids give them more days of data vs servers and which has epg for more channels?
  8. #228
    acid's is always more populated and reliable, yes.
    But here's the thing. You can connect with API or MAC and then get the provider's EPG ... so why use providers in the m3u slot?
    so, use m3u portal and acid's EPG as well as a api portal (API portal populates EPG from server source) and then have both choices. Using API and m3u portals there is no need to add or remove MAC, so easy peasy.
    You will soon see acid's is always better populated with correct data. Server EPG is okay but can be improved and acid does that.
    You can also add a server PlaYLIST m3u portal with server epg url entered and along side with a m3u portal that is for acid , then compare the two just by switching in buzz menus.... easy peasy to switch between them without needing to adjust a MAC
    WE USE TO DO THAT ALSO WITH KENS EPG URL added in there, so that made 3
    You can in effect if you have them all loaded into portals, just switch between at will
    ok how do you switch?
    I got acids on m3u slot and XC API. I see acids is a lot more vs servers but how can I switch between epg? or you mean switch between m3u and XC api?
  10. #230
    yes switch between m3u and api would get you the comparison between acid's and server's epg .
    Even setup another playlist m3u portal with server epg instead of and along side of acids portal, then you have that as another portal to compare.
Tags for this Thread
