I saw another report that acid's EPG was working thru the XR4000 Buzz device but stopped some weeks ago, before the last update.
Am currently reporting findings to buzz team with all this.
thnx guys
thnx guys
well, I think Ryu has solved our problem for us
It's a tricky solution but it works !
I gonna do some more testing before I say, I gotta delete all other portals so I know for a fact I am seeing what I am seeing and its not an illusion
Ryu is the man !!
Okay, I deleted all other active portals, including MAC and API and other m3u portals, so only the m3u with acid's epg is remaining.
We have lift off !!
EPG is populated fully and looks good
I will let Ryu tell the secret
lol
well all you have to do is delete _plus@output=ts from your url
so instead oftryCode:http://xxxxxxxx:xx/get.php?username=xxxxxxxxxxx&password=xxxxxxxxx&type=m3u_plus&output=tsand epg should load.Code:http://xxxxxxxx:xx/get.php?username=xxxxxxxxxxx&password=xxxxxxxxx&type=m3u
another confirmation that this is indeed acid's EPG that is populating, is because the TSN channels are now showing info, which they never do thru the service's EPG
thats awesome.
incidentally now that I think about all this again. that suffix is what gives or allows for certain options, like categories, logos and the like.
Is why you noticed them missing Ryu... we took the 'plus' outta the URL script.
If you check the list of m3u files/playlists there is one listed as Generic M3U and another as Generic M3u Plus (with options).
The 'plus' copy gives the tags for logos and categories and etc...
It sure good to have acid's EPG back
I have missed it for awhile now.
