Page 19 of 34 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 336
  1. #181
    PWA aCiDjEsUs's Avatar
    Jun 2015
    On a mote of dust suspended in a sunbeam...
    just checking now aCiD
    I am having a small issue with populating the epg thou. It is not an issue due to the epg URL, it's the device I am using or the entered input. I had this issue before and did get it working, so I need some time and I will get this flanged up
    thnx again for looking at this aCiD
    Crazed, I hope it's not the size of the EPG, it got a bit bigger but not by that much.
    I was worrying about users that use boxes with less then ideal specs like RAM and so on...but I don't think that'a you.
    I also thought about splitting the guide into two separate guides for English and Spanish speaking channels and making them smaller but then, I know some people have their boxes set one way and for some it's hard to change their options etc..older folks and so on..so I passed on that idea.. will see how that goes.
    Hope all works out
    aCiD
  2. #182
    yea, I am positive my issue has nothing to do with the EPG data.
    I had this happen before and finally switched devices and all was good then. Problem is thou I do not know which device I had switched to, so many choices ... lol
    I got sidetracked thou and have not gotten back to this yet, but I will be working on his tonight.
    JOKER Tha Joker's Avatar
    Sep 2016
    Quote Originally Posted by aCiDjEsUs View Post
    Hope all works out
    aCiD
    I dont see the year. I had an issue with one stb loading but could be me. The other using m3u list, the epg loads fine. I dont see the year in the description tho. I dont see the year with papiaos either using Mac authentication.
  4. #184
    Quote Originally Posted by Tha Joker View Post
    thnx Joker
    I have had a couple busy days at work and have had no time except to drive, work, drive again and then sleep
    While on a channel on that T3, did you try using the down function on the RCU to bring up the hidden menu at bottom of screen ?
    Sep 2016
    Yeah, tried that, hit info while on a channel twice brings up description but no year. You can hit the right arrow too to bring up upcoming epg for one channel but it was the same. I’ll try some other apps in the coming days and see if it’s any different
  6. #186
    Jun 2015
    Thank you Joker for checking, that pretty strange. When I look at the xml date inside the guide I can clearly see the date and I also got an email from SD stating that there should be a year in the data that I pull...
    It might be mc2xml software that I use to get the data from SD and it's not out putting the year. I'll have to look into that more over the weekend why we don't see the year... I know we pull more data because the guide got bigger by 25MB's.
    aCiD
  7. #187
    Jun 2015
    Update...
    So you guys asked for the dates, there you go. There should be release date appended to every movie in the guide and I think shows also but not 100% sure on that one yet...
    It took me a while but I finally figur it out...now time to get some sleep or my wife wont be happy in the morning haha
    aCiD
  8. #188
    Update...
    aCiD
    thnx aCiD
    Jun 2015
    Update....
    Doing some maintenance on the guide so we might be missing few channels here and there. Trying few new things etc.
    Everything should be back to normal by tonight.
    Sorry for the inconvenienced boys and girls
    aCiD
  10. #190
    Sep 2016
    Not able to check at the moment but thanks acid!
Tags for this Thread
