Results 1 to 10 of 11
    Oct 2017
    yes I do
    MAG254 Mode Not Supported Problem
    I played with resolution settings and after the reboot of my MAG254 I'm only getting "Mode Not Supported". The problem is that I cannot get into BIOS by holding menu button. I do know how to get into BIOS, as I've done it about 20x already. Any ideas on how to fix it?
    Thank you.
    take that mag to another TV , a newer TV
    Then if you can see the menus and etc, go into menus and ensueit is not stuck in PAL mode and set the resolution down a notch or two.
    Take back to your TV and check for results.
    Oct 2017
    yes I do
    I tried, didn't work. Any other ideas?
    Android World
    youtube has videos on to fix that issue
    Lets Go !
    Android World
    Try This youtube video below.
    https://youtu.be/4QYACOdiZDY
    Lets Go !
    Oct 2017
    yes I do
    Quote Originally Posted by Bkman2020 View Post
    As I said, I'm not able to get into the BIOS this way. For whatever reason. Actually, I think I am in the BIOS, but the screen says mode not supported.
    Android World
    do u have rca jacks that came with the box and rca connection on back of the tv?
    Lets Go !
    Dec 2016
    yes i do.
    Open Bios on the Mag250/4 by removing the power from the Mag box. Then while holding down the Menu Key on the Remote Control plug the power back in. You will then see the BIOS screen on your TV Set.
    Oct 2017
    Hi iam new with this box mag254 and subscribed with private provider, and he told me to make one url? Do they provide or we hav to make one for url portal? So confuse...
    Oct 2017
    yes I do
    I was able to do it via the RCA cable, no other way to get it done.
    Thank you all.
  1. Not supported mode
    By mentle in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-27-2017, 03:51 AM
  2. my mag 250 say mode not supported
    By vasan in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 05-29-2016, 07:23 PM
  3. Mode not supported
    By NONOBADGIRL in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-27-2016, 08:19 PM
  4. mode not supported
    By supaman32052 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 04-04-2015, 06:00 PM
  5. Mode not Supported
    By milady in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 03-20-2015, 01:37 PM
