Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
  1. #21
    Nov 2016
    ok
    Both boxed do not connect.
    Was fine yesterday.
    Trying to watch NASCAR...
    Help Please.
  2. #22
    are you sure that your server URL did not change ... in all my private dealings, that is one of the top reasons why the connection is lost on a code that should be working fine.
    Re-Check the website for the URL that it shows there for your code.
    Nov 2016
    ok
    In IPTV portal on website p1.iptvrocket.tv matches url server 1 on box
  4. #24
    Nov 2016
    ok
    If the default IPTV Portal URL doesn't work please try the full version http:// p1.iptvrocket.tv/c/index.html
  5. #25
    Nov 2016
    ok
    I tried this also and no good
  6. #26
    Nov 2016
    ok
    I went to market and loaded utube app.
    It loaded and ran.
  7. #27
    Quote Originally Posted by nobravo View Post
    It loaded and ran.
    I do not know what else to tell you bud
    You have checked your code and if the MAC matches the avov you are trying and the server URL matches and all the rest of the stuff only you can see... Beyond me looking at your code, I do not know... the service is up.
    TSN channel with nascar is down thou
    Nov 2016
    ok
    what are you calling the code ?
    Donation ?
  9. #29
    Nov 2016
    ok
    Who can help me further ?
    Both boxes went out at the same time.....
    Strange !!
  10. #30
    Donation ?
    when I refer to the code, it is referring to the credentials that get you logged onto the service website or onto server thru iptv.
    3 things make up a code...
    and with that code used at the website,you then see everything about that code (server URL, MAC assigned, expiration time, etc... and perhaps IPTV Reset )
    Private code consists of...
    - your email or perhaps Client ID if bought from a reseller.
    - 12 or 13 digit Donation or Route number.
    - 16 digit Order number.
    Simplifies things.
  1. Can not connect /connect failed
    By KingTech in forum IPTV Private Server (Rocket)
    Last Post: 12-11-2017, 03:48 PM
  2. can't connect
    By sylvia in forum IPTV Private Server (IPTV66)
    Last Post: 01-02-2017, 01:02 PM
  3. cant connect a 254
    By joeh in forum IPTV Private Server (Rocket)
    Last Post: 12-04-2016, 07:49 PM
  4. Box will not connect with vpn.
    By 793bob in forum IPTV Private Server (Rocket)
    Last Post: 09-25-2016, 02:51 PM
  5. can't connect
    By dtvbandit in forum IPTV Private Server (NFPS)
    Last Post: 09-07-2016, 07:08 PM
