Results 1 to 10 of 19
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Lightbulb EPG Guide Source for (Generic m3u w/Options) Playlists
    EPG Guide compiled for channel ID matching of NFPS Generic m3u Playlists.
    (*Not sure if Rocket and IPTV66 use the same Channel ID's, but give it a try!)
    Use this URL address directly in your App,
    hxxps://raw.githubusercontent.com/kens13/epg/master/guide_kens.xml
    * Change hxxps to https
    or click on the link below with a browser, then right click the resulting text in the browser window and then click "Save page as", and give it a name with an .xml file type.
    https://raw.githubusercontent.com/kens13/epg/master/guide_kens.xml
    Aug 2017
    yes i do.
    Works with IPTV66!! Great work.
    Jul 2017
    epg
    Buen trabajo, gracias...un saludo
    Confirm it works with Rocket. Thanks Kens great work.
    Sep 2017
    i have a subscription that works fine but no guide does this discussion above give u a tv guide
    Feb 2016
    yes i do -Y(not)
    Yes it does.
    The URL for the Guide is noted in Post#1
    Oct 2017
    Hi my reply hasn't posted - have done this for perfect player in my quest for UK EPG that has new format sly channels and when assigning the channels come up as numbers, is there 1) a URL for perfect player or 2) a way I can look up the numbers/ a key?
    Oct 2017
    Can I edit your playlist in a browser and delete channels and will it still load? My provider has basically stripped all non sport channels out (which is a pain)
    Feb 2016
    yes i do -Y(not)
    You can edit "your" playlist with a text editor.
    This Post is for a guide source that matches Channel ID's in the M3U Playlists provided by NFPS.
    Otherwise, it is hard to understand what you are referring to.
    This guide will work in Perfect Player(Android only)
    PC Version is completely different... and it sucks because of the setup problem.
    Oct 2017
    Ok thanks, I am looking for an EPG URL to use - and assign channels but the channels come up as numbers not names like in a previous guide I use. So I can edit in notepad, save as an .XML? Then how do I reference the file from a fire stick? Upload online somewhere?
  1. EPG Guide Source Expires Dec.18th.
    By kens in forum EPG
    Last Post: 12-10-2018, 02:04 AM
  2. New Guide Source for Stalker/PotatoTV
    By kens in forum EPG sources
    Last Post: 06-22-2018, 03:25 AM
  3. Reproduccion Generic emu3
    By robtami in forum IPTV Private Server (IPTV66)
    Last Post: 03-17-2017, 12:29 AM
  4. Generic android tv box.. what to buy
    By Viktor79 in forum MyGica Android TV Box
    Last Post: 07-28-2016, 08:16 PM
  5. Add options to Guide Menu please
    By matrixebiz in forum EPG
    Last Post: 12-13-2015, 10:26 PM
Tags for this Thread
