Results 1 to 10 of 17
    Member Barry The Barber's Avatar
    Global Box Updated
    There is a update today.
    Fixes the volume issue.
    This makes this box the best iptv box.
    Picture on the TV is just excellent.
    After the update your box should have a Build Number 20170910
    Enjoy your Global Box
    May 2016
    Yup
    Quote Originally Posted by Barry The Barber View Post
    great news.. I couldn't stand that audio issue anymore so I had stopped testing. thanks for the heads up!
    Owned devices: Nvidia Shield (2015 & 2017), Minix X8-H Plus, U1, U9-H, Dreamlink T1, Dreamlink T1 Plus, Avov Tvonline, Global media box 4k, Mi box, Buzz xpl2000, Buzz xpl3000, T95Z Plus, Formuler Z7+ (UK & NA)
    Apr 2016
    Canada
    Exclamation
    When and how does the update happen? cause I turned on the unit and nothing shows of any update in progress ?!
    Do I have to go --> All apps ---> and click on update ?or is it donw automatically cause I don't see anything showing update happening?
    my build number is reading 20170804 so I guess my unit did not get the update?!!
    May 2016
    Yup
    My box didn't prompt for update either. Is there an external file we must install manually?
    enter MY TV app and where you choose the portals, enter into Settings and then exit back out.
    You then may see the prompt for new update.
    Is how I got it here.
    Build now shows as 20170910
    To view Build version number.
    Enter the hidden menus by depressing the 8 digit, 7 times.
    If you already are in the hidden menus, then scroll to Settings and then in System enter into Info
    with this new update, seems that now when the box boots up, itd goes directly into the hidden menus.
    No more needing to depress the digit 8 seven times.
    May 2016
    Yup
    I just went to my box to try as you suggested and the prompt for update was on the screen right as I turned the tv on. Guess it just took a while to push for me
    Apr 2016
    Canada
    Hi Fellows,
    I tried what you suggested Crazed, but no update prompted for my box?! still reading 20170804
    Quote Originally Posted by montell View Post
    Hi Fellows,
    if using wifi, try a hard wire connection
    Apr 2016
    Canada
    I only use hard wire and never wifi.
  1. Global Media Box 4K - New
    By Barry The Barber in forum Global Media Box 4K
    Last Post: 02-02-2021, 06:25 PM
  2. CTV and VAN.Global
    By Rinny in forum Helps us Improve!
    Last Post: 02-23-2019, 11:38 PM
  3. Just Got my Global Media Box...but :(((
    By montell in forum Global Media Box 4K
    Last Post: 09-09-2017, 04:57 AM
  4. global tv
    By macmac in forum Kodi Discussion
    Last Post: 06-08-2015, 04:16 AM
