I have been unable to find any info on how to set up the AVOV 2 using the Ethernet ?
I did an advanced search - -took me to this forum .. so hope I'm asking this in the correct section.
I tried to get my AVOV 2 working using the Ethernet -- I had it hooked up using wifi -- but I also have an avov 1 --
I hooked the avov 2 up to another tv -- and couldn't get the correct IP address to roll up ?
Spent couple hours, then thought well, maybe because the AVOV 1 is hooked up - -so, attempted to get it going via hard wire ..
NADA -- it did show the green speaker lite, ver=1.5 and the date and time came in just fine -- but - could not download any of the apps ..
tried setting it on "static" and manually inputting the correct ip data --then switched back to DHCH -- to see . .nada.
if there's some instructions out there anywhere on hooking up the Ethernet -- pls point me in the right direction if you can..
thanks much !!!
