Results 11 to 20 of 24
Thread: pvr
    Apr 2016
    Canada
    Quote Originally Posted by NBS View Post
    for playback go to apps,pvr video
    When I go there, all I get is a Black screen with Pvr video on the left top corner of the screen and "Long Press "ok" to Del Video File" on the top right corner of the screen and nothing else of my recording list ?!!
    Apr 2016
    Canada
    I guess no one really knows how this box works ?
    not many have this box yet.
    NBS and a couple staff here do have it. I do not thou.
    But it sounds like either that seagate is not compatable or maybe change the usb port it is plugged into.
    Unplug the Global box first before switching the USB port.
    Apr 2016
    Canada
    Thanks crazed for the reply.
    Problem is not the seagatehard drive, the problem is as I mentioned above to playback I go to apps,pvr video and "all I get is a Black screen with Pvr video on the left top corner of the screen and "Long Press "ok" to Del Video File" on the top right corner of the screen and nothing else of my recording list ?!!
    Warrior
    Quote Originally Posted by montell View Post
    its not he box either as i have no issues
    what did you format the drive to?
    You can also hit the menu button in live tv and select pvr from there
    Apr 2016
    Canada
    when I do record onto my hard drive with no problem.....its hard to find the recording and once found it does not play well....
    Last edited by Capt.Kangaroo; 11-16-2017 at 05:44 AM. Reason: deleted non relevant to thread info
    Warrior
    So you don't answer questions and then talk about other box?
    Apr 2016
    Canada
    My apologies my good friend...my head is not with me nowadays
    Warrior
    again ,what did you format your drive to?
    Munstah posted it should be ntfs
    Apr 2016
    Canada
    it is Ntfs.
