Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    okay, in that server menu where you can enter up to 10 servers, enter into one server slot what I have below and then connect.
    1.iptvprivateserver.tv
    And with that MickeyHop platform I bet that is how they would disable your receiver if you don't pay per 3 months.... Very bad deal that is
    Cause you are paying them to run a server to supply you with APPs.... And plus the more expensive price for the receiver too, While an original avov does not charge for their server (same MickeyHop platform). That Hybrid even uses avov software for petes sake
    Anyway, they don't control any private server you may use, so enter what I posted there and connect. Let us know what happens.
    Quote Originally Posted by Freddy12 View Post
    Yes and the apps are free.
    actually from what I am beginning to understand, they aren't free in your case. You pay for them every 3 months. The thing is, they have the ability to disconnect you from their MickeyHop server.
    Without that connection then your receiver will not work, not even for a separate private server application (cause the needed TVOnlinre APP is found on that server).
    So basically they are charging you to host the APPs found in your Channel Store.
    that's how I see it, I may be wrong if there is other factors involved but doesn't look like it.
    If them server slots are empty then they are not suppling you with any IPTV server content thru that, and that would make sense for the charge, but nope.
  1. hybrid box
    By janet b in forum MAG 275 and 277 Hybrid
    Last Post: 01-23-2017, 11:06 PM
  2. Setting up new Hybrid plus box
    By brijshit in forum IPTV Private Server (Rocket)
    Last Post: 09-25-2015, 08:16 PM
  3. hybrid +
    By batyan in forum aVOV VIXO1
    Last Post: 09-16-2015, 07:44 PM
  4. hybrid +
    By batyan in forum aVOV TVOnline
    Last Post: 09-16-2015, 07:07 PM
  5. Hybrid Plus Ip TV BOX?
    By bruenor9 in forum Android TV Boxes
    Last Post: 08-07-2015, 02:03 PM
