Hello guys, please help , I searched the net and could not find any info on that box. I purchased it and it's working fine, but I just need a forum or a section where I can read about it.
Thanks you again guys.
Is this the box ..
Code:http://www.kijiji.ca/v-electronics/city-of-toronto/hybrid-plus-tv-box/1069145577
that box is basically same as an aVoV Vixo1 or clone there of.
We've seen them before, it's a clone or knockoff of the avov receiver. It'll work same as the avov vixo1 model.
Stick with that in mind and anything the Vixo1 gets as updates and such so will your Hybrid model.
It's higher price then an Vixo1 original , which it should not be but ....
C/P
Box Includes:
aVoV TVONLINE Player, Remote Controlller, AAA Batteries, Power Adapter, HDMI Cable
HYBRID PLUS TV BOX
Thank you so much for the reply. When I purchased it I paid more then the Avov price a little bit pricy like you said. But the thing is I have to make payments every 3 months. Can you tell me why is that? Or can I just take over the box. Thats the help I needed it. Please and thank you.
Is there a Channel Store in the menus ?
Check in your Channel store and see if there is an APP called TVOnline. If there is, then you can use that to connect to a private server, which will cost money as well thou. But check for that APP and see if it has been installed or is it running a server already.
Also check to see what is loaded onto the receiver as far as receiver software is concerned and let us know. That's found in the Settings menu some place.
Also are there other APPs in that Channel Store ?
Well I tried clicking on the menu on the remote, it did not work but I can see the TVonline on top of the screen where the channel lists are available. When I go on My Apps , there's no app called Tvonline only 9 app 8 of them are porn and the 9th project free tv.
Plus I can connect to 2 servers.
okay, the TVOnline app seems to be part of the receiver's user interface. That's how the aVoV TVOnline box works as well. While the Vixo1 and Vixo 2 avov models have the APP in the Channel Store and needs to be installed.
When you say My Apps, what you have there are Apps that have been installed already. You can freely uninstall any APP and reinstall them too, as long as you have access to the Channel Store.
What you wanna look for is the Channel Store or Mickey market. that's where the APPs are found and are free.
And what about receiver software ?
That's found in the Settings menu.
http://iptvtalk.net/showthread.php?1...to-set-up-IPTV
http://iptvtalk.net/showthread.php?1...AVOV-TVOnline-!
check those two videos in them links above. On is the Vixo1 model and the other is the TVOnline model. You'll see the slight differences between the two and then go from there as to how to work yours.
Where you see the servers is part of the TVOnline APP (that's what the APP provides, which is a server menu and an access point to connect to the server).
Thanks again for your help. The setting menu in both video are the same and did find a market that's powered my Mickyhop with not a lot of options and apps and no app called Tvonline. I clicked On the miracasr tab and it's running on android_7e24. And it running on 2 servers DLNA and AIRPLAY. How can I use my own server without paying the monthly fees?
The TVOnline app is where the private servers are entered.
That TVOnline app may be embedded into the receiver already. That's shown in the second video.
Does your box work the same as in video 1 or in video 2 ?
And still need to know what software is on that box.
And no private server is free, unless it's in a beta test period like NFPS currently is.
Them APPs found in the Channel Store are free.
My box works like the second video, where you can enter up to 10 servers. I am not sure where I can find the software on the box ( I am new to this) please let me know. How much would it cost for a private server and how do I get it please.
Thank you very much.
Yes and the apps are free.
