Can one connect Can connect Mag 259 and Mag 254 IPTV Box to a Slingbox, so can use Slingplayer ?
If so, which Slingbox model you use for it to work ?
Unless there is an HDMI input on the back of the Slingbox I do not see a way it can be done, I have the solo and it does not have the right connection for HDMI but I'm not sure what the newer Slingbox has.
I think it would need component outputs from Mag 254 in order to work. I don't think Mag 254 has that ?
Search youtube "HDMI, your Slingbox & you" about it.
So I guess there is no way in making it work ?
Are there any IPTV boxes which Rocket would support, which have component or composite outputs out of the list already mentioned ?
